Wirsbo brass fittings and heat
  • Wirsbo brass fittings and heat
    Hi,
    I had to correct a couple of wirsbo fittings and had difficulty cutting the PEX off them without damaging them so i heated the brass fittings to melt away the plastic (even that took time). My questions are: Has the heat in any way compromised the brass fittings? I used a regular propane torch, blue cylinder. What is the best way to get the tough PEX off of these fittings in order to reuse them?
    Thanks
    Re: Wirsbo brass fittings and heat
    The Wirsbo siminar I went to the instructor first cut off the outer ring with a sharp box knife then used his electric heat gun to heat the tubing and it slid right off. I'm sure that a propane torch would be safe to do the same as long as you only added the heat neccesary to soften the plastic tubing.
      I added enough heat to melt the tubing off.
        I allways cut them off with a box cutter. As long as there is no pex residue on the fitting I don't think the flame would have hurt the fitting.
          If the brass is clean and not burred then it is ok to re use.
