Clogged Kitchen Sink Drain Line
  • Clogged Kitchen Sink Drain Line
    Last week I had a kitchen sink line clog on me. The nearest cleanout in the basement was about 6 feet away and maybe 3 feet of head pressure. I was surprised at the velocity and volume of water that covered me when I removed the plug to rod the line.
    I used a rag to cover the plug and a bucket to catch the water but it failed to protect me from the drenching.
    Is there another technique used by plumbers to divert the flow of water in full or partially full drain lines when you need to open a cleanout and rod the line?
    Re: Clogged Kitchen Sink Drain Line
    Originally posted by Big Jim
    Now that you've been baptized, how about just opening the clean out enough to let water trickle out without removing it all the way? May take a while to drain down, but better than getting drenched.
    sometimes the obvious is too simple
    steve
      That makes to much sense. What about a vertical stack? You can't catch the water. Use a mop?
        attack it from above. otherwise you make a lake of nasty and that's a whole 'nother story
        steve
