Vent size
  • Vent size
    Hi,
    Can you confirm if I can use 2 1/2 inches vent pipe in Canada. Canadian plumbing code charts uses 1 1/2, 2, 3, ... inches but not 2 1/2. If yes, is is available easily on the market?
    Thanks
    Re: Vent size
    Originally posted by alupien View Post
    Hi,
    Thanks
    why
    are you using a lot/long copper?
      Re: Vent size
      Yes about 300 feet
        Re: Vent size
        Yes about 300 feet
        You should be able to use any piping that meets the minimum requirements of your code and installation.
        Ex: If minimum requirements are 2.5" calculated to cover your fixture load then there should not be a reason that you couldn't use 2.5" even though it is not known as industry standard.
        Somtimes calculations for sizing can come in between the typical used materials.
          Re: Vent size
          Hi,
          Thanks
          In the 1995 plumbing code, the charts include 2 1/2" pipe. As far as availability , I have never seen any 2 1/2" at any wholesalers.
          West Trail Mechanical Ltd
          www.westtrailmechanical.ca
            Re: Vent size
            copper dwv or gal pipe, but not sure if they make any dwv fittings for it.
              Re: Vent size
              2 1/2" very very rare good luck finding fittings.. go 3"
                Re: Vent size
                we deal with an engineer who loves to spec 2.5" pipe as a waste line size. we always end up getting an addendum to upsize, what a PITA.
                  Re: Vent size
                  2.5" vent is still on the state journeymans quiz here.
                    Re: Vent size
                    Last I checked when you can find 2 1/2" it's a lot more expensive than 3".
