more code
  • more code
    are slip nuts allowed to used behind walls without access?
    Re: more code
    Not in my Code. IPC.
      Re: more code
      no you need access
        Re: more code
        NO. Not now, not ever.
          Re: more code
          Only kind of but you have to replace the slip-joint washers with brass ferrels.
            Re: more code
            Not here but even if it was, it wouldn't be a good idea.
              Re: more code
              as mark mentioned. we would install bathtub waste and overflows with brass slip joint nuts, and brass ferrules on 17 gauge r.b. tubing.
              the ferrule was an accepted method of joining and didn't require access. i preferred the 1/2 ferrule or the good old days of the soft lead ferrules.
              still have lead in the shed
                Re: more code
                Is that like the old saying "lead in the pencil?"
                  Re: more code
                  the only reason i ask is because i made an access panel to the pipes for my upstairs tub and as i opened up the floor i found that the trap and everything was threaded together. there was no access prior to what i did. my condo complex was finished in 88 and is all piped with ABS. so this isnt supposed to be at all???
                    Re: more code
                    Buried (hidden) nuts are outlawed in NJ.
                    The squirrels are protesting but it is doing little good.
                      Re: more code
                      so these are a no, no???
                        Re: more code
                        I was making a funny. :-)
                          Re: more code
                          are these connections against code?
                            Re: more code
                            A bunch of people have basically told you that non-accessible slip joints with nuts are against most codes.
                            Why are you asking?
                              Re: more code
                              We didn't mean to confuse you but when the slip joint washer is replaced with a brass ferrule it is no longer a slip joint fitting it becomes a mechanical fitting.
