Gfi
  • Gfi
    Customer had pump plugged into a normal grounded outlet.
    Outlet was replaced with a GFI and tested ok.
    When pump is plugged into the outlet the circuit disconnects.
    Re: Gfi
    Ejector or sump pumps aren't supposed to be plugged into GFCI outlets.
      Re: Gfi
      I believe the pump should be on a dedicated circuit, so you wouldn't need a GFI.
        Re: Gfi
        Having a dedicated circuit is not the reason for not needing a GFCI.
        The small amount of current (5mA) required to trip a GFCI is the problem.
          Re: Gfi
          good to know!
            Re: Gfi
            good to know!
            There's more to know than just the 5mA figure.
            Read up: http://en.wikipedia.org/wiki/GFCI
            OSHA eTool on GFCI
            http://www.osha.gov/SLTC/etools/cons...ents/gfci.html
