retardation of flow and back flow plumbing problems
  • retardation of flow and back flow plumbing problems
    most of our sales offices experiences this kind of plumbing problem, after the flushing out water in the water closet, the retardation of water (lowering of lower to be more specific) is very evident. There are also times wherein we experience backflow? How can we solve this problem? I am suspecting that there are no vents installed in the system. Thanks in advance
    Re: retardation of flow and back flow plumbing problems
    more likely a siphon leg due due improper installation or a partial stoppage.
    true lack of proper venting can also cause this.
    pictures would help.
      plumber rick,
      thanks for the reply... at least i know that I'm in the right track...
      Granted that I need to place a vent in the system, how will I incorporate it if the system is already set/ installed? Apparently, the vent stack thru roof (VSTR) is embedded in the masonry walls. The structure that the plumbing system serves is considered to be very old (The structure is approximately 30-40 years old). Are there other ways to address the problem?
      Thanks in advance and more power to RIDGID forum...
      Note: This site really helps newly licensed civil engineers like me
        Are you in Metro Manilla? If so, we have a member here who might be able to help. Michael Stephen is in Manilla.
