Sewer Vent Question
  • Sewer Vent Question
    Hello everyone,
    The city recently installed a new sewer line at our house. Now I have two 4" pvc pipes sticking out of my yard, one with a clean out cap and one with a drain cover.
    I'm putting in a new lawn, and with these two pipes sticking up 12" right in the middle of the yard I would like to cut them back to grade so that I can mow right over them. Will that cause any problems as long as I keep the drain cover free of debris?
    Thanks!
    Dan
    Re: Sewer Vent Question
    If you could post pictures, that would be helpful.
      They are opposing clean-outs, meaning that you can snake to the street and back to the house. If you cut them flush to the ground you can install new female adapters and plugs on them. Just slip them over the outside of the pipe DO NOT cement them so that you can easily change them when they get broken (and they will definitely will get broken).
      WE LIVE IN THE LAND OF THE FREE,
      ONLY BECAUSE OF THE BRAVE
        Thanks Chauncey for the reply, and the great photo.
        My only concern was that the city vented the one clean out with a drain screen (in the picture, its the one closest to house). Will I cause problems with the system if I cap it?
        Thanks,
        Dan
          I'm not sure i've ever seen a drain screen like that on an outside cleanout. I'd love to know the thought process behind that
            That's for a house trap. (I think)
              ohhh good call. I've never actually worked with a whole house trap. Would a vent like that go in downstream of the trap itself?
                No the vent is on the house side of the trap. Cool air enters, it warms and rises causing a constant fresh air change in the system.
                How Deep is it?
                If it is a whole house trap it should not be buried out side as it could freeze and it will definitely plug up one day.
                Check with the local inspector and find out if a house trap is required in your area.
                Maybe have a camera inspection to be sure of what it really is. Maybe the contractor that the city hired didn't have a second co fitting and just used anything he found in the truck.
                  I went out and pulled the covers off.
                  I'll start with the pipe closest to the street. I measured down, it is 24" below grade, then the pipe sticks up out of the ground 12". so a 36" run to the surface. The connection below is a tee, not a wye.
                  The pipe closest to the house is a different story. it is 30" below grade plus the 12" above grade. For a total run of 42". The pipe runs out of the house, 90s up at the vent, and then connects to the run with a tee.
                  I had my wife flush the toilet, and I could see water in the trap at the first pipe, water slammed into the 90 and then flowed out to the street.
                  Looks wrong to me, but I didn't pay for it, the city did. It made it through one winter. Any hopes that this will be somewhat trouble free for me or future owners?
                    No.
                      Some may not like this,but it will work fine. Buy 2 plastic [ green] sprinkler boxes.
                      Cut down both pipes and re plumb as they were. Top of cover should be flush with new lawn surface.On the one closest to the house[ whole house trap ,I think,the cover of the plastic box will need about 10- 1/4" holes to vent the trap SHOP,SHOVEL AND SHUT UP!
                        Yikes...
                        First three things I learned when I got into plumbing.
                        1. $h!t flows down hill.
                        2. Dont bite your fingernails.
                        3. Pay day is on Friday.
                        According to this picture, your sewer is flowing uphill.
                          What is the rational behind a whole house trap? I don't see them here, think they are redundant, and don't see any advantage to having one. Wondering if anyone can shed some light on what they might be good for.
                            Sewerage traps were and still are designed to stop sewer gases from entering the property especially a building.
                            Tony
                              We have them in S.F.. One inspector said " with the extreme steep hills ,it helps with fast
                              velocity from siphoning the inside house traps. Also keeps out rats"
