Megaflow Pressure Reducing Valve Leaking
  • Megaflow Pressure Reducing Valve Leaking
    Hi All,
    I have a Megaflow Pressure Reducing Valve that is steadily leaking. It leaked a bit last year and a plumber took it apart and changed a rubber o-ring I think but now its dripping again.
    The assembly has a shut off valve on the mains supply side.
    I wanted to replace the cartridge if possible but was wondering if it will create issues with the megaflow (any blancing/bleeding required) or if I should be wary of doing this myself.
    The replacement part I believe to be as follows...
    http://www.uk-plumbing.com/megaflo-p...r-p-42232.html
    I will of course check this first but I believe it to be the right one.
    I have a reasonable level of competance having plumbed in my loft conversion but I didn't install the megaflow (looked a bit too complicated !!!)
    Any help would be greatly appreciated.
    Re: Megaflow Pressure Reducing Valve Leaking
    Anybody? Bueller....Bueller?
