driven well
  • driven well
    Hello,
    Stumbled across his forum, and am hoping this is the right place to ask my question.
    First, some background:
    Drove a 1-1/4" well year before last. Got to 27 feet and didn't hit water, so I drove a 2" down. AT 55 feet I hit water. Drove down another 15 feet. In the process, I tore my rotator cuff and also a tendon in my forearm. Decided to just lay off until the next year at that point.(decided that a year too late, I think) Went back to it, and found that the pipe had bent at about 40 feet. So I cant get my 1-1/4" galvanized pressure pipe down to force the water up.
    Now we get to my question. Does anyone know if I could get away with using plastic pipe? I think I know the answer, but am just hoping my labor wasn't totally wasted.
    Thank you.
    Re: driven well
    Plastic is fine
      Re: driven well
      Driven point over 32 feet? How do you plan on getting the water up?
        Re: driven well
        I need to pump water down to force water up.
          Re: driven well
          yeah do you have some type of jet that fits down a 2inch pipe?
            Re: driven well
            Bottom line, turn loose of the hunny's and get a well contractor. Cheaper than a shoulder injury.
              Re: driven well
              foot valve at bottom. Put in 7 of these when I lived on the cape.
                Re: driven well
                What you need is called a packer jet. Goes down the 2 inch casing and uses the 1.25 as the suction line. Uses a regular jet pump up top with a packer adapter on top of the 2 pipes.
