Sump Outlet - How High
  • Sump Outlet - How High
    Hello,
    How high off the outside ground should I make the sump pump outlet thru the wall? Most of the houses in my area weren't built with sumps so there aren't any examples I can see.
    Thanks!!
    Re: Sump Outlet - How High
    In my area the cement wall is about 8" above the ground on the outside. Then they lay a sill plate, then on that is a box header, maybe a 2x10 or 12. with in that 2x10 or 12 is where stub our sump pump discharge out
