Switch on Sewage Pump
  • Switch on Sewage Pump
    The switch on my pump has failed for the second time in six months, with minimal use. I know I have power because when I unplug the tether and plug the pump in directly it works. I find it hard to believe the second switch has already failed. Any one have any ideas why?
    Thanks, Brenda
    Re: Switch on Sewage Pump
    I'm assuming you are talking about a float that controls the pump.
    A power spike could take it out. A nick in the outer casing of the wire when it was installed could cause it. It could have just been a poorly constructed float from the factory.
    www.ClinkscalesSeptic.com
      what brand are the pump and switch? breid
        The pump is a RIDGID Aquapro 1/2 horse the float I am not sure, I have not taken everything apart yet. I do know the switch I replaced in Dec, 08 was a SJE Micromaster.
        If I had a power spike wouldn't the ground fault have tripped? Thanks
          It should have. This may become helpful. http://www.sjerhombus.com/buy/warranty.asp
            If the pump cycles frequently that can burn up a switch quickly. frequent cycling can be due to the installation, or to a check valve on the outlet side hung open.
