Old Toilet Repair - 2" Brass Drain
  • Old Toilet Repair - 2" Brass Drain
    This 2" piece is from an old toilet. This pipe feeds water from the wall mounted tank to the bowl. and is leaking at its connection. I think it is brass only because of the brassy color when I scratch it. How do you suggest this be fixed? Can I come up with a replacement piece of copper, PVC or whatever? Should I take it apart and try to re-solder? I have never messed with brass soldering.
    Re: Old Toilet Repair - 2" Brass Drain
    Give Home Plumbing a call, and ask for Ron Sr. They are based out of Villa Park IL and he has a nice little parts shop that may have the part you are looking for. Tell him Ronnie from A-Archer recommended him to you. Here is his phone # (630) 833-8146‎
      do as ratz says. also they maybe able to fix it if need be. i would try to replace it first, as you will have all new works then. breid
        It's been a while since I tried, but those were available in 2" chrome. IIRC, there are different offsets and lengths.
