Is a Dielectric Union Necessary on EVERY water heater?
  • Is a Dielectric Union Necessary on EVERY water heater?
    Have been told that going copper right into the top of the tank, a dielectric union is not necessary. Galvanized yes, copper, no.
    True or False?
    thanks!!!!
    Re: Is a Dielectric Union Necessary on EVERY water heater?
    True or False?
    thanks!!!!
    False, you have it mixed up. Copper to the water heater needs either a dielectric union or a brass fitting to make the transition. Galvanized can be hooked directly to the water heater just fine.
      When I did full service plumbing I hooked up water heaters with direct copper connections. The tank will go bad long before the connection will.
      Transition from galvanized to copper in every other case requires a dielectric union, IMO.
        i've seen a few that leaked, but that was along time ago. none recently. yes on galy to cop.
          I usually install brass nipples with dielectric unions. The best way, in my opinion, is to use stainless nipples with dielectrics. That's with copper water lines, of course.
            brass nipple with fip x sweat ground joint union is how i do em..
