trap primer not working ???????
  • trap primer not working ???????
    installed 2 ppp pr-500 for 2 floor drains. Ya now I know 1 would have taken care of both.
    Haven't checked the 2nd one but one isn't working. how does the allen adjusting screw work?? Arrows are installed correct . and this is not the one that backed up on the drain line test. thanks Tool
    Re: trap primer not working ???????
    Are you getting enough pressure drop?
    Some have problems when they rough in close to a low volume fixture,I.E. drinking fountain.
    Others too far away in the middle of the system.
      PR-500 shows "Prime Right".No adjusting.
        i'm sure you know this but no pipe dope! or like dirty said not enough pressure drop i think its needs something like 10# or so..
          They are both close to the faucets 12" of so. I use unions ,and pipe dope. I'll check them for debrea next week. PRV is set at 60 psi for home. Thanks Tool
            Remove the other primer and install it in place of the non working one. But, first flush the line and no pipe dope, just tape. Quickest way to determine whether the primer is defective.
              This is a laundry tray with standard 2 valves. Good flow. Can You please explain pressure drop ,and how it is affected in this application ,Thank's Tool
                tool, years ago we were allowed to use trap primers that had an adjusting screw to dial them in for the proper flow. the way they operate is when they detect a drop in pressure. they open to provide a drip to keep the trap wet/ primed.
                but in the last 20+ years we can't install trap primers with the adjusting screw or a dedicated shut off valve. this is to keep people from shutting them off.
                the pressure drop is required to allow them to open. if there is not enough of a pressure drop they remain in the closed position and defeat their purpose of supplying water to the trap.
                i'm sure a few steaks and i can fix it right up
                  PPP - P500 Trap Primer web page
                  Instruction Sheets
                  Prime Rite - PDF Plugin Required
                  P1 and P2 - PDF Plugin Required
                  John Ruskin (1819 - 1900)
                    Give him a holler on your flyover home and he can toss'em up to you.
                      Thanks guys,Plumbus nailed it! Way to much pipe dope from the old DOPE ! Cleaned both of them up ,adjusted the allen set screw, works fine. I do like the adjust option,are these against code for Me in S.F.?? Cal .steam stocks these. I realize in general,I'm using too much pipe dope, That is over. Yes only tape this time. It says right on the Unit NO DOPE OR
                      NO GUARANTEE! Stupid G. C.S, TYPICAL!!
