Pipe Reaming
    Re: Pipe Reaming
    For a mechanical room with a lot of fittings and room for a table, these are nice and not just for reaming.
    http://www.ridgid.com/Tools/122-Copp...e/EN/index.htm
      Re: Pipe Reaming
      My boss has one of these, I just haven't had a chance to use it yet. It would be nice for 1.5" and 2" though. I got carpal tunnel syndrome when i worked at a factory, then I was a bungalow buster, and cut a lot of tube by hand. Just a couple of hand cuts and the old carpal tunnel comes roaring back.
        Re: Pipe Reaming
        Originally posted by Bogart View Post
        I have never heard about the step drill, I will have to try it if I ever get a big enough job. Most of the copper I do now is 1.5" or bigger. I usually cut it with a band saw, and hit it with a half round file.
        Do you really need to ream the pipe?
          Re: Pipe Reaming
          No, it's just to dress up the o.d. of the tube.
            Re: Pipe Reaming
            I either use the built in reamer on the tubing cutter or the little pencil reamer
            Same here man, but I have used a step drill before. Ridgid copper prep machines are awesome for production work as well, we had one at the first company I worked for.
              Re: Pipe Reaming
              Yes, it helps reduce friction and roil and makes the pipe and joint last longer. Not to mention the codes requiring it.
                Re: Pipe Reaming
                Thanks for your sharingThanks for sharing this useful information. It's great.
                taux credit auto - Taux crédit auto. Comparatif des
                offres! Les meilleurs taux crédit auto sont sur le net !
