Low water pressure outside for water slide to pool
  • Low water pressure outside for water slide to pool
    Hi - I need help with a water faucet outside. I have a pool with a water slide, below the slide is a water faucet to hook up the water to the slide. When I turn it on, water comes out however the pressure is not high enough and does not spray from the slide. I purchased new tubing for the water to run through so that is not clogged. I am hoping someone can please give me some advise on how to fix this myself. Thank You!
    Re: Low water pressure outside for water slide to pool
    IS there a shut off inside the house for the line, check to make sure that valve is all the way open. If it is all the way open close it and pull the tap apart at the slide to see if it is blocked
      Are the spray nozzles clear? Did you have enough pressure before?
        Test the slide with a hose from a different faucet to rule out the slide..
        If ok turn off the water and take the faucet apart,,,flush it with the stem out and see what happens..
