Fluidmaster 400A & TOTO Drake Toilet
  • Fluidmaster 400A & TOTO Drake Toilet
    Can any of you think of a good reason not to replace the "POC Brand" with a Fluidmaster 400A?
    Re: Fluidmaster 400A & TOTO Drake Toilet
    you're correct. the original is a hunter design.
    it doesn't hold up near as well as a fluidmaster and parts are much harder to come by.
    when i can fix them i do. when i can't they get replaced by a fluidmaster.
      Thanks and I kind of thought you were the person that howled about TOTO needing to switch over to Fluidmaster. I was thinking maybe they had something hidden in the tank so as to force exact replacement with the same POC that comes in them. 400A is will be.
        The Toto G-Max flush system uses a higher refill rate on the bowl refill. If you want a lesser flush go right ahead and use the 400A.
        411 Plumb Appliance Stimulus Package
          Toto G-Max
          Is a nice reliable fill system w/ fast fill. It takes about 10 seconds to fill my ultramax which is nice for those needed courtesy flushes I say stick w/ the Toto system.
            does anyone know how to adjust the blue button and the black plastic screw inside the tanks.
              Hi everybody
              Hi everybody,
              I am new to this site.I hope this site will help me to understand quickly.
              I would like to say "hi" to all members,Welcome to the forum.
