Help my tub
  • #46
    Re: Help my tub
    Chief there should be a wide spot in the slot the bolt goes through.
    on a side not thinking of all the times I had to cut a tub drain to snake the line clear....
    Hmmm
    Hmmmm
    Not even a single handful in all the years I've been plumbing....
    411 Plumb Appliance Stimulus Package
    • #47
      Re: Help my tub
      dont varry you take m seal and cover where will the water floow][/url]http://telekomx.mobi/lp2/iwaay.plumbers[url]
      • #48
        Re: Help my tub
        Glad you got everything working with the tub. Why didn't you use a shielded coupling like others mentioned before? (No hub band, MJ band, proflex etc.) Not to nitpick or anything. Those fernco fittings are allowed where I live but I much perfer to use a shielded coupling. Practice installing them on a scrap as Rick mentioned in another post and you will learn to love them. They have so many uses and can really help you out in a jam.
        Good luck with any future projects
