Tub Spout Diverter Life
  • Tub Spout Diverter Life
    So why do diverters on my tub spouts die every couple of years. They leak more and more as time goes on until its hard to get the shower to kick in.
    I asked a worker at HD if any of the higher priced Tub Spouts lasted longer and they said no they are pretty much all the same.
    So is it true.. its is just a fact of life that I will have to replace em every few years?
    Josh
    Re: Tub Spout Diverter Life
    Do you have hard water? The buildup was killing all my plumbing fixtures when I bought a house with hard water. I put in a softener just recently when I re-piped. I already think it 's helping.... no white crud at all anymore.
      Just like with most things, HD sells mostly crap. I have seen a HUGE difference in the variation of quality in tub spouts. Go to your local supply house and they should be able to set you up .
        Thats what I figured... HD's selection is pretty narrow and the spouts feel more like tin cans than a fixture. They are cheap though. I am all for paying more if it lasts.
          josh, the spout that you're having problems with is probably a front lift diverter style. made of cheap pot metal and a rubber cup washer to seal against the metal inside a plastic slide
          typically the all brass constructed ones with the rear lift are much better quality and much higher $$$.
          put together a list of goodies and we can all pack some parts.
          remember that i can only pack so much stuff and still have room for my games
          post a photo, you know better
            What's the water pressure like? Too high will destroy the little rubber cup in no time.
            Be sure to state if its a copper pipe or a gal nipple type spout.
            (The Low Spark of Steel-Toed Boys)
              Josh,
              As the others have said check your pressure, and try a Delta # RP17454.
              411 Plumb Appliance Stimulus Package
                I was cleaning out my shed the other day and came across some old solid brass Chicago tub spouts with the diverter. Each spout weighs at least 5 pounds each. If I do not sell them by the round up I bring one with me.
                  Pressure isnt very high. Its copper running into the spout. Rear design doesnt work because the connection is all the way up in the front of the TS.
                  Sorry about the hacked terminology ;-)
                    Find a high quality boutique plumbing store and see what they can do about getting a high quality spout. Remember the copper bit, though. You might want to take an old one with you as the boutique people can be clueless.
                    Plumbing quality has really dumbed down, so get the best you can. Instead of a rubber cup diverter, look for a brass diverter.
                    Or install a shower stall.
                      I just had trouble with one today, first it leaked out of the spout. After I was able to fix that it leaked from where it threaded onto the 1/2" nipple. I don't get why they can't just make something in between the $10 crap and the $60 ones.
                        vette. my guess is that there is no market for them. you either want a good one or walmart will do. breid........
                          Spout supply can be shortened Josh.
                            So I guess all of us who want something in between do not provide enough of a market for these sub-standard manufacturers....hmmmm
