Can a standard water heater be side-vented?
  • Can a standard water heater be side-vented?
    We have a Standard Rheem Water Heater, model: PRO40-40FV1 [See link below]
    40 Gal 40,000 BTU/H That is currently vented through the house's original chimney which needs to be removed (50+ Years old). It leaks water badly and is falling apart. The water heater is almost new (1 yr old) and works fine. We don't want to put up a new chimney or flue up the side of the house. Is there any way this water heater can be side vented? Or other way we can keep it?
    If not our only other option is to buy a new power-vented water heater ($$$)
    Thanks!
    This is the water heater:
    http://www.rheem.com/product.aspx?id...B-0294D6064957
    Re: Can a standard water heater be side-vented?
    Sorry,
    The heater shown needs a draft/draw.
    Certain amount of feet rise to draw the gasses up and out before offsetting to a certain degree.
      You can buy a side wall vent kit made by Tjernlund but that might cost as much as a powervent water heater.
      www.Tjernlund.com
        go electric
          If your water heater is near an outside wall you can go with a direct vent water heater. They are a bit more expensive, but do not require electricity to run a power vent. http://www.bradfordwhite.com/product...1&product_id=7
            Where I live we are allowed to tie the exhaust from a water heater into the furnace exhaust. Check with your local building jurisdiction to see if this is an option. Might work.
              Why can't you run the flue straight up from the water heater?
                Sorry,
                I found this out the hard way as I didn't know this about the newer water heaters. I ate that 50gal water heater and had to put in a power vent.
                Go with a power vent!!
                  I bet that hurt.
