Can't Install then test your own work?
  • Can't Install then test your own work?
    Is there a code rule somewhere that states that, "If you install a backflow assembly device, you can not test that same device."? A buddy of mine in Texas tested a device, and they refused his test report, and was told that he can not test his own work (RP installation). This sounds like $hi* to me. Texas Plumbers???
    Mick
    Re: Can't Install then test your own work?
    well on every rough plumbing job,Iinstall and do a head ,and pressure test!
      That's how it is for us. If we install then we can't certify.
        Here, you need to be a plumber to install RP's and you need to be a cross control tester to test RP's. I install and then test them.
          That makes sence to me. I'm not a plumber, so I can't install. I can only test and repair.
          My buddy in Texas can install and he test's. But his water board won't accept his test reports saying that he is not allowed to test his own install. Does that sound right to you, or just like some water people being a little over zealous?
          Mick
            Is there a reason for this crack? What happens if you were working for an outfit that has multiple plumbers? Could one install, then another test?
            Mick
              Mick
              I'm sure the D.C. government could come up with a dozen reasons why we can't. We are allowed to test yearly after the initial certification.
                In Illinois you can install it and test it, as long as you have a CCDI. (Backflow License)
                  I don't do testing yet, but this sounds like b.s. to me.
                  Are you talking about annual testing? So he/she can't test one they installed three years ago?
                  If so, that's b.s. ANY certified & licensed tester should be allowed to do the testing. The documented tag and record is the checks and balance that holds them liable. A municipality gains no further protection of the system or from conflict of interest by denying the original installer to test & maintain.
                    In NJ you must have MP license or be working under a MP to replace or repair, You need the State BF tester cert to test, and you can test your own installs or repairs.
                      My Buddy's initial test report was denied. I don't know about them accepting annual test's being accepted after the initial test.
                      I agree! The way that I look at it is that there is integrity involved. If a plumber has to be licensed, insured, certified, and approved up the ying-yang to do any work, then has to be certified and insured to test backflow's - I would think that there would be an implied sense of honor and integrity to go with the pride in someone's work.
                      Mick
                        If they trust to you put it in, they should trust you test if it, if you hold the required certs/license. It's one more cost that the gov't is putting on our shoulders.
                          Well if it falls under plumbing code, then it has to be third party certified, if it has to be inspected. Around here anyways.
                          I wouldn't trust the installer to test his own work. Why would you? If Joe Blow is installing these, and testing them, who is to say he is installing them right? Him? Why not just let all plumbers inspect their own work? If they could, I GUARANTEE there would never be a red tag again. I think it is BS that each city can bypass any portion of the code they want to, but it doesn't matter what I think.
                            Just to add here in Illinois the only way to get the CCDI License is to be a licensed plumber.
                              I'm not sure if you completely understand what the original poster is referring too. He's not saying that that he wants to install a backflow without an inspection. He's saying that they are trying to refuse annual testing on a backflow from the original installer. Unless I'm confused.
                              You may not have an annual testing program for your area. But it would be like you installing a backflow, having it inspected, then the next year being refused to perform the testing procedure on it because you installed it. Or the year after, or the year after that.
                              And I also think it's BS that each city can make an attempt to bypass any portion of the code they want.
