Ball Valves-Compression Type
  • Ball Valves-Compression Type
    Is there any disadvantage to using compression vs. sweat type ball valves? The reason is I am going to be plumbing a hot water coil into my coal furnace and would like to have the "option" of re-using the valves if I don't like the configuration.
    Thanks
    Re: Ball Valves-Compression Type
    No.
      If you don't mind your work being instantly recognizable as amateurish, use compression valves. I and most plumbers can unsweat and reuse solder fittings if need be.
