Valve location
  • Valve location
    A couple of months ago I was helping a friend of mine install a tub valve. I believe it was a Delta. The instructions said to install the valve from 7'' - 18'' from the faucet. It wasn't an issue as it was new construction. If this was a remodel in a one piece tub, like a Lasco, with the tub valve at say 42'' the spout could be no lower than 24'' down from the spout or about 9'' above the rim of the tub. What's the issue about the valve being no further than 18'' from the spout?
    Re: Valve location
    There is no issue
    It will work were ever you put it
    they have to put something on the paper in the box
      Re: Valve location
      Thanks Del, it didn't make any sense to me when I read it either.
        Re: Valve location
        put it where the holes are. breid................
          Re: Valve location
          LOL, new construction... I put the holes where I wanted 'em.
