Toilet Placement
  • Toilet Placement
    My present toilet has a 14" space between the hold-down bolts and the back wall. While shopping for a new one I was told that all toilets now are made for a 12" rough-in. He said the new ones are okay to install and will just be a couple of inches away from the wall instead of up against it. I can live with that so I bought a Cadet 3 based on what I've read on this forum. When looking at that install specs it states you should only use the model that fits your rough-in. Will this stool be okay on the 14" rough-in?
    Thanks, Big G
    Re: Toilet Placement
    Thanks, Big G
    It will work fine. But it will have more air space between the tank and the wall behind it.
    It is incorrect that "all toilets now are made for 12" rough-ins".
    10", 12", 14" are available.
