sump pump switch
  • sump pump switch
    I installed a new Ridgid SP-500 submersible sump about a month ago. I saw an initial problem with it in that when the float triggered the switch, the pump would only discharge water for about 2 seconds. this kept the water level, well, level, but did not remove much water from my crock.
    I came home from work tonight, and the pump was running continuousely, and there is no incoming water (i.e. rain) into the system. i am assuming it is a bad switch, but Ridgid Customer Service closes at 5pm eastern time. Is the switch difficult to replace? Where can I get one--Home Depot? Lowes?
    thanks
    Re: sump pump switch
    Almost every plumber i know will not install a ridgid sump pump. They area home depot thing. ZOELLER seems to be the brand of choice from plumbers in my area!
    sorry ridgid
      take it all back to homers. get your money back do something else. breid.............
