Going rate for installing gas line
  • #31
    Re: Going rate for installing gas line
    Originally posted by MoJourneyman View Post
    The lowes here will cut and thread the pipe for you if you bring them your cutsheet. Rather discouraging.
    That can get expensive if a person has an intricate system.
    One or two measurements off as much as 1/4" and he's out of the wall and bowing drywall.
    • #32
      yeah, you wouldn't want to try it with an intricate system, but with a quick run I have to imagine its appealing to the diy community
      I use a 300 <.<
      • #33
        Thanks for the encouragement. No cutting involved...I bought a variety of parts right off the shelf from Lowes and HD (Lowes was out of unions )...ended up with just a couple of short nipples leftover.
        The line was checked for leaks with a sniffer of some sort....it seemed pretty sensitive. I was told by the dealer and the contractor that there's a pressure regulator going into the house that should keep everything within range for a typical residence. The town looked it over and issued a certificate of compliance, so hopefully we're good to go!
        Now, onto the mantel, which I'm a bit more comfortable doing.
        • #34
          Sorry for the delay...been busy finishing up other things with the fireplace. Thanks for the encouragement. I bought the parts right off the shelf from Lowes and HD (Lowes was out of unions )...ended up with just a couple of short nipples leftover.
          • #35
            This is my brother Hewood
            And over there is my other brother Hewood.
            • #36
              • #37
                On Gas, no unions inside a home ,here! LR COUPLINGS
                • #38
                  Damn Tool! Reminding me of a job I have to do tuesday, not liking it.
                  9' up in the air, I wet myself on ladders. Would rather stay grounded at all times.
                  • #39
                    Even at the appliance? Must make changing out a gas valve quite a project
                    • #40
                      unions are legal at the fixture and outside. nothing inside/ under the building.
                      • #41
                        You know what I mean, wise guy
