Radiant heat manifold location
  • Radiant heat manifold location
    Need some advice on a radiant heat question. I need to move my manifold from it's current location. The only logical place to move it to is on the side of the boiler my question is, are there any restrictions on where the manifold should be with regards to the boiler (is there a min. height or distance to the boiler?)Also, my radiant zone is for a basement bath and was installed in a poured slab...I forgot to run a temp sensor in the cement is there another way to install a temp sensor? there is access to the radiant tubing when it enters and exits the cement slab can I install one there? Thanks for your help.
