96% furnace discharge
  • 96% furnace discharge
    In S.F. new furnace filtered water discharge needs a re locate. Have area drain in floor. Unit was discharging there 2 " above floor drain. Insp. wants it into laundry tray. Negative fall! could drop tray 4 ", I guess. What is the required fall,please?1/4" per ft.? Yea,guess I'll call the Insp. and ask.
    Thank's for any ideas. Floor is all tiled.
    Re: 96% furnace discharge
    1/4 " fall on all pipe 3" or smaller here
      you can dump it into a condensate pump and then pump it anywhere you want from there.
        BINGO, $48 BUCK FIX ! You get one of Rick's stakes! Tank's Tool
