Bad gurgling sound takes a turn for the worst...
  • Bad gurgling sound takes a turn for the worst...
    We recently bought a a 1964 split level and the drain in the bathroom one level up (about five steps) from the kitchen has always gurgled a bit when you use the kitchen sink or dishwasher, but tonight after doing a huge sudsy sink full of dishes my daughter reported the bathtub had bubbles coming up from the drain! Is this obviously a vent issue? I don't even know where the main vent is! water and bubbles traveling against gravity can't ever be good.....Any help would be much appreciated...
    Re: Bad gurgling sound takes a turn for the worst...
    Depending on how your home drains are set up, I'm guessing your main line is partially clogged, perhaps roots.
      Was the home empty for some time before you moving in?
      Do you notice when a large volume of water is used the "gurgling" is worse?
      Do you have a basement clean out?
        Thanks for answering back...it wasn't vacant and yes the gurgling is worse when large volumes are being used. I have no idea where the basement clean out would be...it's a tri-level split so the lowest floor is the family room (a sort of partial basement, maybe 1/2 of it below grade.) Is that the same as a household trap?
          In my area household traps are common in older homes. Your area I'm not sure.
          Is the bathtub the lowest drain in your home?
            It's not the lowest, that's the problem -- it's on the top floor -- above the kitchen
              So we have narrowed it down to one floor and eliminated a main line blockage.
              Good.
              any other drains on the same floor causing a backup into the tub or causing gurgling sounds?
                OK Sallyc I'm guessing your problem will get worse, but you have logged off.
                Good luck!
                Call Roto-Rooter
                  Thanks so much! It's just the one drain and yes, we need to take care of it before it gets worse!
                    Sally, Please don't use Drano! It's bad for the environment, destroys the drain cables [You
                    can be billed for this] and can burn the skin and clothes of the drain clearer! Ask Your friends for the name of a drain clearing [ small outfit ]Co.in Your area, that has a good reputation. Large National Co. are getting a Rep. for tacking advantage of Good folks.
                    Ask about Jetting the lines,It clears soap scum real good .Good luck ,Tool P.S. Please Report back! We'll be of good help next time!
