Water Pressure Test
  • Water Pressure Test
    We have recently taken over a new house in Italy and there appears to be a water leak and we asked for a pressure test to be carried out. This the plumber did and recorded a loss of 25% pressure over a 5 hour period, going from 10 bar (145psi) down to 7.5 bar (110psi).
    The plumber claims this is within acceptable tolerances, but it seems very high to me.
    Thoughts/opinions please
    Re: Water Pressure Test
    Wat too hi 60 lbs is good
      Any water leak in my area is unacceptable.
        toolaholic,
        The system was put under an artificially sealed pressure test and the above loss recorded, but with normal pressure of 60psi and the system closed off it went down to 45psi. Still showing a 25% loss
          were all the fixtures turned off or capped off. such as toilet ballcocks?
          is the pipe running underground/ slab?
          was the test performed with water or air?
          if it's air, it's a larger leak than with water.
          remember that air compresses and water is a hydraulic.
          it takes very little water loss to drop the pressure.
          what material is the piping?
          how much is underground?
          can you isolate the underground?
          do you need me to go there and help you out
            Busted didn't read it through. I'm sober now!
              See - That's another thing that I like about this forum so much!! People are quick to lend a hand and help out without any regard for personal sacrifice!
              Mick
                Originally posted by tuffareo View Post
                toolaholic,
                the system was put under an artificially sealed pressure test and the above loss recorded, but with normal pressure of 60psi and the system closed off it went down to 45psi. Still showing a 25% loss
                drink wine ,not water !
