Valve/switch for switching to a second H20 source when a storage tank is empty?
  • Valve/switch for switching to a second H20 source when a storage tank is empty?
    I'm new to this forum, but it looks really helpful. I have a house from 1896, so I'm sure I'll be here asking questions pretty frequently.
    I'm trying to set up a system to collect rainwater and groundwater that my basement sump pump usually pumps out to the street and use it for my toilets and outside spigots. I think I've got most of it figured out, but I'd like to be able to switch to my main water supply when the tank is empty. Any suggestions on doing that? Is there a valve that will stay open to one source when it has pressure and then open for the other source if not?
    Thanks,
    Aaron
    Valve/switch for auto switching between sources
    Assuming someone has a well and is hooked up to the municipal water supply as a backup, is there a valve that will swtich to the municipal supply if the well pump stops providing water?
      Re: Valve/switch for switching to a second H20 source when a storage tank is empty?
      A simple float valve in the tank.
        Thanks, drtyhands. A float valve in the tank will tell the monitor the level of water in the tank, but how can I get the plumbing to switch to the municipal water supply when the tank is empty? Forgive me if I'm not understanding.
          It seems what you need is a float switch which will open a solenoid to the city water and close a solenoid to the storage water. These type of systems must make sure you take cross-connection control into consideration and are probably not legal in some areas.
            Thanks. Yeah, I wouldn't want to be violating any laws or allowing the rainwater I'm collecting to be introduced into the city water system. I guess I'd just have to connect the rainwater tank/pump directly to the toilets or spigots to eliminate the risk of contamination. I was just trying to avoid running out of rainwater. Maybe I'll start with an outside spigot and see how that goes.
            Thanks for the advice.
