power vent hot water heater problem Page Title Module
    Re: power vent hot water heater problem
    You may want to pull the mollex connectors out of the gas valve and check to see if they are burned. I've had some bad wiring harnesses on that same heater. Usually end up changing the gas valve and wiring harness if thats the case. Call ao smith tech support and they will send the parts to you. May need a qualified installer to install them. Just my 2 cents.
    Brian
      Originally posted by Jay Mpls View Post
      Do a google search on what a flame sensor rod is and give a a cleaning then enjoy your hot water.This is a VERY common problem.
      What do you guys like for cleaning these?
      I like steel wool but have heard some guys use emery cloth!
      scotchbrite
      411 Plumb Appliance Stimulus Package
        The AO Smith rep told me to use a dollar bill, but I go with the scotchbrite, too.
          Hi Monday evening water cold again rechecked groung continuity checked OK also ckecked ground connections in breaker box everything tight .Then removed flame switch cleaned with steel wool visually checked wiring looks like new replaced. plugged heater into wall outlet fired right up like a new one.Will let you know if it still working properly in a few days.Thank you everyone for all helpful input so far.riproarin
            Hi Saturday evening heater still working fine thank you for the help
              the ground path through a power vent water heater is checked using a mulit-meter set to: a: volts, b: amps, c: continuity
