Pipe Trades leaking
  • Pipe Trades leaking
    just put a shutoff valve on the cold water side of a hot water heater this weekend and used T Plus 2 pipe tread sealant on all the fitting and have one that leaks and can not get it to stop, Do i need to take them all apart and put Thread Tape and Sealant too?
    Re: Pipe Trades leaking
    I use both on threaded fittings.Tape,3 wraps,then dope/teflon compound
    2 hits (Or just 'some'!)
      Thanks i will try that too night and see if that stops it
