Toilet stub?
  • Toilet stub?
    If I remodel my bathroom this winter do I need to worry about the new low flow toilets being built in a different manner in relation to the floor flange? Is the standard placement (I think its 12'' from the wall) of the flange still the same? Thanks!
    Re: Toilet stub?
    If your rough in dim is 12" off the wall you are all set, anything else you will need to order a special toilet, eg. 10" rough or 14" rough
      Re: Toilet stub?
      Thanks Wrench.... I should be all good then!
