Why is bathroom sink drain still slow?
  • Why is bathroom sink drain still slow?
    Hello Friends........
    I finally replaced the entire sink drain, p-trap etc. all the way to the point where it connects to the cast iron 1 ½” pipe T inside the wall. However,
    The SINK DRAIN IS STILL SLOW, almost clogged !
    Please share more information
    Thanks
    GreatForum
    Re: Why is bathroom sink drain still slow?
    I think you already said it: "the drain is clogged". You did the obvious and most common checks, which is the pop up assembly and the trap, but it just turns out your problem is further down...needs a cable job.
