Life expectency of a water heater
  • Life expectency of a water heater
    What are You seeing of the ones installed in say 1995,2000,2005 ?
    what should folks expect for reem ,bradford white.AO smith? Tanks Tool
    Re: Life expectency of a water heater
    So far as my experience goes I find that they are all pretty much lasting the same depending on the quality of the water. I used oto say that I found most tanks to last at least 20 years till I moved here and they had no filtration system for the local water supply. That meant tons of sediment in the lines and botom of all water heaters. They were lucky to last 10 years. Now we gopt a state of the art system I have found repairs on many valves etc. has reduced by over 80% and am confident that tank life also will benefit. Just watch your relief valves and anode rods, changing when necessary and you should be good.
      Thank's Shock. In N. Calif, Marin Co. We are blessed with great water. I feel so bad ,reading
      about the problems folks have elsewhere!
        .....probably flushing at least once yearly also buys time for a heater. jmo
          Indeed it does. My water heater is 15 yrs old and we have terribly hard water here and it's been flushed regularly and still performs awesome. Fingers crossed it will keep kicking for a long time!
            For what this is worth I'm still using a 50 gallon RHEEM gas fired water heater on city water that's not all that great. This water heater was installed in the fall of 1983 (really) so I feel lucky it has lasted this long. I do flush it out about every 6 months and every few years replace the T&P safety valve as it gets mineral deposits inside it. I keep a spare one here and try to blast it manually into a bucket about once a month. If it leaks afterward, then it gets replaced fast. The anode has never been replaced as I found the old one in too tight and didn't want to risk doing more harm than good really putting serious torque to it.
            Keeping the insides clean is a must. Also I set it for 125F shut off and leave it there. Most likely it will be replaced before too long as far too much heat is going up the flue pipe. A newer one would pay for itself on fuel savings. I just hate to get rid of my old trusty friend.
              Right-electric-situation......life!
              http://www.rheem.com/product.aspx?id...D-B33125C50F64
                My condo complex was built in '85 with State gas WH. I replaced my own in 2004 "just because". I saw one being taken out this weekend, and "peeking" into the pation closets, I see there are at least a few more left! Maybe the builder got a really good batch???~!~!!
                  I would say average life of a gas fired water heater here is 6-8 years.
                  Pathetic.
                  I know for a fact there has been manufacturers in the past that put their tail between their legs and run when they hear what we have for water, etc.
                    Years ago Bradford White did a presentation at a local restaurant for a large group of plumbing contractors in our area and one of the questions that was thrown at them regarded wanting to know what the difference was between their 6 year water heaters and their 10 year heaters. The more they avoided this question the more times it was brought back into the discussion. Finally they quietly admitted that there was no difference between their 6 and 10 year tanks. Their final statement was that they only make 1 type of tank and all are built to 10 year specifications! When you buy a 10 year heater from them your really just buying the warranty. We were selling hundreds of Bradford White heaters a year and after giving our customers the price and warranty options along with this new tank information we found that on average 90 out of every 100 heaters sold by us were 6 year heaters.
                      Sometimes the long warranty gets you a "kit" which included a beefier anode rod to install.
