are ball valves available in 90 degree angles?
  • are ball valves available in 90 degree angles?
    ....just curious. i love ball valves and just wondered if they are available in an angle version? sweat or threaded doesn't really matter.
    Re: are ball valves available in 90 degree angles?
    Like this one?
      Any sizes or applications in particular?
        ......1/2 and 3/4. sewerRatz shows the ones i had in mind.possibly use for clothes washer.
          Try Dahl mini ball Valves...good products, I have used them many times.
          http://www.dahlvalve.com/default.aspx
            Thanks Chemeng
            SewerRatz - Whose ball valves did you post? Those look very nice! I've never seen those before, although I'm sure there are a lot of things I haven't seen before.
              Liberty Valves Private Limited is a well-known name in the area of valves. We are a leading manufacturer, supplier and exporter of all types of Industrial Valves like Ball Valve, Gate Valve, Globe Valve, Check Valve, Butterfly Valve, Y-type Strainer Valve, Sight Flow Indicator, etc. Our valves are available under the trademark 'Liberty'. Established in 1965, today we stand tall in our arena, having achieved several milestones. The trust and support of our customers worldwide have kept us going in this competitive market.
              Industrial Valves Manufacturers
              Delhi
                Any time I am searching for a specific fitting that I am not sure is made I just use google and in a few seconds u will know.
                The Plumber/Firefighter
                  Install a 90 degree flood stop valve, water sensor and save a washer
                  flood disaster !
                    How's about a 5 way ball valve. You can cover more angles that way.
                    http://www.apollovalves.com/products...=16#Five%20Way
                    BTW: The standard valve I carry and use in my truck is the Apollo Ball valve series 77-C. I get them in swt, threaded and Propress. As far as I'm aware Apollo ball valves are the only ball valves made in the USA. It's a small way to support jobs in America while simultaneously installing an excellent valve!!
                    Although Apollo does import ball valves for the "competitively priced" valve market.
                    I used to install Kitz valves but after seeing dozens of them start leaking right through the brass after a few years I'm done with that.
