how do you unfreeze a 246 soil pipe cutter?
  • how do you unfreeze a 246 soil pipe cutter?
    Hi, I jammed up my 246 soil pipe cutter and I need to unjam it. Basically I ratcheted it to tight and the outer arms are jammed against the ratchet hub. The open procedures are locked out (nothing will move) and I'm reluctent to do any forcing. I don't have an IPB so if you can help please be specific. Thanks in advance J M----------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------.
    Re: how do you unfreeze a 246 soil pipe cutter?
    Use a 4" grinder and remove the link pin heads. Then drive out the pin
      i jammed my cutters up about 2 wks. ago , i took 2 pipe wrenchs to them with some force they came unjammed. ive done this several times with no problem, spray down with wd-40.
        i have the same exact problem . OP, did any of the solutions work? i wish they were more descriptive.
          where did you use the pipe wrench? on the rachet arm? adjustment bulb? thanks in advance
            I have the same exact problem .
            Tmart com LED Search Results Security Surveillance Electronics Toys Hobbies Computers Networking Car Accessories Laptops Accessories Cell Phones Cameras Photo Video Games Health Beauty Home, Office Garden Sports Outdoors Flashlights Lamps Laser Pointers Holiday Supplies Gifts Apple Accessories Apparel Clearance.
              My 246 has snap rings on the ends of the pins which are easily removed.
              Once this is complete, the pin can be driven out with a brass drift.
              This will usually allow you to loosen the adjusting screw and put back together.
              you may have to play with the knob to get it to turn.
              I use liberal amounts of WD40, through out the process, except when reassembling, I used wheel bearing grease-'cause it was on the shelf.
                thanks in advance. i find myself somewhat mechanically capable and don't like asking for help but i am stuck on this one!
                which pin are you referring to on this diagram
                http://www.ridgid.com/CatalogDocs/246.pdf
                  just to clarify, which pin are you referring to here on this schematic
                    thanks for the reply
                    are you referring to the pin that is on the eyebolt? or is there another pin (eg. on the CatalogDoc 246 pdf exploded view)which you can refer to?
                      I am referring to the center pin #34445.
                        Put the soil pipe cutter's lower portion in a vise. The portion where the Hook assembly and the Chain assembley are attached to the tool. The Ratchet handle housing should be at the top. Put the directional arrow pointing toward the words OPEN on the Housing. Now, push the Handle in the direction the arrow is pointing. This may take a lot of force which may require a cheater over the handle.
                        If this fails, please feel free to send back to the RIDGID Factory Service Center. The address is:
                        321 Sumner Street
                        Elyria, OH 44035
                        Thank you,
