dielectric heat trap and dielectric union question
  • dielectric heat trap and dielectric union question
    does the dielectric heat trap has the same function as dielectric union? I think my hot water tank needs a dielectric union and a heat trap.
    thanks,
    Re: dielectric heat trap and dielectric union question
    What is your reasoning for thinking you need these?
    I can answer better once you give us that information.
      My electric hot water tank starts leaking and I am thinking about replace it. Right now there is no union there which is recommended by the manufacturer. heat trap is recommended by somebody online
        Don't even consider installing another electric tank in it's place. Use that new boiler to heat the hot water. Have the plumber install a mixing valve and you won't need a heat trap or dielectric unions.
          It really depends on what state you live in and what there codes are, some states require the die-electric unions even though most of the new good brand name water heaters ( bradford white, rheem) have them now built in with the heat trap. i personally have used them for many years with no problems, but now with the new water heaters having them built in, i no longer use them unless the code requires it.
