Energy Kinetics 2000
  • Energy Kinetics 2000
    I own an Energy Kinetics 2000, instaled 7 years ago and now it is short cycling while failing to hold temperature. Our plumber/installer has been here at least a dozen times, spoken with tech support at Energy and has replaced, the primary control, the heat exchange, and other parts but cannot seem to figure out why the unit continues to short cycle even when it is not calling for heat. Help.
    Re: Energy Kinetics 2000
    http://www.energykinetics.com/classi...gerDiagnostics
      Thanks for the diagostics site for the system 2000 by Energy Kinetics. Problem persists. I've changed the primary control, both acquastats, the heat exchanger, I have a temporary board in, and it still short cycles down to 90 degrees, though it does work properly but on an intermittent basis. I never know if I will get up in the morning and have hot or cold water, not to mention heat. I trying to avoid a new system given this one is seven years old. What are we missing? Thanks
        well, what is the delta t between outgoing and incoming water?
