bad smells
  • bad smells
    a shower waste is smelling
    it goes from shower to floor waste gully which is traped
    some people use expensive shampoo conditioner
    which coates the side of pipe
    which make pipe smell
    what chemicals can i use to get coating of side of p.v.c pipe
    Re: bad smells
    Bio Clean will work, and it is safe. The following is from Statewide Supply's website.
    BIO-CLEAN is... a blend of bacteria and enzymes. The bacteria are natural, not genetically-engineered. The enzyme concentration is the most powerful on the market.
    Bio-Clean is non-poisonous. It creates no heat, no fumes, no boiling. It does not attack live tissue nor inorganic materials, only organic wastes like grease, hair, food particles, paper, cotton & sewage. This makes BIO-CLEAN safe for people, plumbing and the environment. BIO-CLEAN changes the waste particles into water, carbon dioxide and mineral ash which run harmlessly out of your waste system. These elements are then available for plant life.
    Within an hour after pouring the bacteria into the drain, the bacteria begin to eat their way into the waste that has accumulated on the sides and top of the drain pipe. This is their natural food. They digest the waste and spread throughout your system, cleaning it completely
    Residential and commercial applications
    All drain and sewer pipes, including:
    Kitchen Sinks Lavatories Bath tubs Showers Floor drains Laundry drains Septic tanks and drain fields Garbage disposal odors Grease traps Sewage ejector sumps Outdoor outhouses and cesspools R.V. & boat holding tanks Lift Stations Cat Litter Boxes
    100 drain treatments per 2 lb. container
    2lb. container treats 1,000 gallon septic tank
    Eliminates the need to clean grease traps and cable drains
    Eliminates the need to buy dangerous chemicals
    Eliminates the need to buy deodorant blocks (urinals.)
    Eliminates costly compensation to employees that have been injured by using dangerous chemicals.
