shower valve replaced
  • shower valve replaced
    I recently had a shower only valve replaced with the removal of one ceramic tile to get to the old one. I am being charged for six hours of labor is this an acceptable time for replacing the shower valve assembly? Thank you. lo
    Re: shower valve replaced
    It can be. Each one is different.
    So if you ask a friend that had one replaced and they say, "Mine only cost x. And only 3 hours labor". This will not be the case for ANY other situation.
    In short, it can take 3 hours or it can take 8 hours depending on what's there, what happens, what's being installed.
      Did it take six hours?
      And replacing a valve from the tile side, usually takes longer than if they cut the sheetrock on the backside.
        can't see it from here. the last one we did took 2 of us 8 hrs. depends on what expected. breid.........
