looking for help
  • looking for help
    i am a antique tool collector . i have discovered an old pipe cutter and would like to get some info on this tool to keep in my files is there an antique or vintage section here or does anyone know of aforum that covers old tools of plumbing . thank you bob w.
    Re: looking for help
    If you post a picture of it I bet someone here will be able to give you more information on it.
      i will try the cutter has a floating wheel jar that is not connected to the handle when you open the jaws the wheel jaw has to be pulled down . the screw handle will close it .bob w.
        [/IMG]
        try again
        i give up bob w.
          When you post a msg if you scroll down to additional Options You will see a button that says Manage attachments, use that to add a picture.
            How to upload an image file
            Your text goes here.
            And/Or put text here too.
            1. Click on the paper clip
Name:	SNAGIT_000 12-12-2009.jpg
            2. Find your file
Name:	SNAGIT_001 12-12-2009.jpg
            3. Check file size does not exceed MAX allowed
Name:	SNAGIT_002 12-12-2009.jpg
            4. Click UPLOAD button
Name:	SNAGIT_003 12-12-2009.jpg
            5. Insert the image in your post
Name:	SNAGIT_004 12-12-2009.jpg
