Westbrass pot filler question
  • Westbrass pot filler question
    I ordered a Westbrass pot filler and taking an advanced look at the instructions online it says it comes with a 1/2” NPSM nipple (straight threads).
    Has anyone installed one of these? Is it just the end that goes into the faucet and the other end is NPT?
    Where would I get NPSF fittings?
    Re: Westbrass pot filler question
    For mine I have not only set a F.I.P. drop eared ell screwed in with #10 X1" screws(not brittle easy snap drywall screws) I clamp the drop/riser/whip whatever you want to call the supply to the ell.
    Then penetrate with a 1/2" NPT through a 2X6 set flush with backside of drywall to recieve the four screws that will come with your filler.
    Most of the time the so called plumber just stubs out a nipple with innadequate support and the simple turning on of the water at full extension cracks the tile and grout.Thing flops around like a dead fish
    How'd I do
      I went out to Lowes last night and pulled it down from the display and it definitely has straight threads. I e-mailed who I thought was the manufacturer who is apparently just a distributor and they were not very helpful.
      Will straight threads seal in a tapered fitting? why would they make it like that?
      My question:
      Your pot filler faucet says it comes with a 1/2" NPSM nipple (Straight thread). Is that just the side that goes into the faucet and the side that goes into the wall is a tapered NPT?
      What fitting is available for NPS female in the wall?
      Their response:
      The manufacturer recommends using silicone seal on the threads as a thread compound; although they say Teflon tape also works well when threading into a winged ell.
        What I ended up doing was putting my pipe threader in a vise and putting a taper in the brass nipple.
        It had an interior hex in the end the faucet screws in. Of course it was .475 across the flats so I ground down a bolt with a half inch head so I could jam it in there and put a vise grips on the end of the bolt and turn it in the die (the threader hole is longer than the nipple).
        I was amazed at how easy the soft brass took threads.
        I still don't know why they made it so hard.
          Learned something new here!!!
          "Pot filler" I thought you talking about one of these
          http://www.tpub.com/content/UFC1/ufc...0_13fn0192.htm
            the straight threads allow for the pot filler to easily screw flush with the wall. sometimes a 1/2'' + or - is a bit long or short for a pressure fitting to fit tight to the wall. tub spouts are the exception as there is no real pressure on the spout when it's on or off.
            silicon is a way to glue and seal it to the set depth.
              The supplied nipple was 2 7/8 inches of straight threads. I couldn't find a winged ell that had straight threads and didn't feel right putting the straight threads into the tapered fitting. Was this feeling misguided?
              The faucet end is deeply threaded. I got some locktite thread sealant for the faucet end.
              another Rick
