remove a tap
  • remove a tap
    I have a caroma "brass ware" tap and I can not get the handle off. It has no visable screw under the hot and cold plate and none on the side. I have turned off the water at the mains but can not screw the head off, is there a trick ???
    Re: remove a tap
    I am sorry, I can not be of any help. I have yet to come across one of them. If I seen one up close I could figure it out. Maybe someone here has fixed one of these in the past will chime in.
      Re: remove a tap
      I didn't even know Caroma made faucets.
      I thought they only made china fixtures.
        Re: remove a tap
        Here is a link, but when i click on their technical tab for a faucet I get a broken picture. http://www.caroma.com.au/product-ranges/taps They also have a plumbers handbook, but only shipped in Australia http://www.caroma.com.au/plumbers-handbook
          Re: remove a tap
          I hate to tell you this Lady call a plumber as you need a special tool.
          Tony
