what kind of faucet is this
  • what kind of faucet is this
    i have an apartment complex with alot of these tub/shower valves can't figure out what brand it is can someone please help me thanks raymond
    Re: what kind of faucet is this
    Looks like Symmons.
      hmmmm, I have never seen this body and cartridge set-up...
      Is this installed in a nursing home (I rulled out a hotel by the pictures) or is this a straight residental install?
      As a first guess I agree with JC
        this is located in a government apartment complex built in 1959 but the valves have been upgraded at some point in their life problem is mud tile on a double brick wall with about 4" between between the walls. other problem fed funding has been cut so they want to try to repair them instead of replacing them
          i can't find any thing in symmons either ive since changed this valve with a 1300 series delta so i have the complete valve now i would send it somewhere if someone might could figure it out ive sent the pics to different faucet parts companies online and nobody seems to be able to figure it out thanks for everyones time
            That loop handle and the connection looks like Symmons to me. I have very little experience with them though.
            Looks like the front end of a KN-4 cartridge but the back end does not look the same to me. Almost looks Delta-ish.
            http://www.chicagofaucetshoppe.com/P...e=SYM%2DKN%2D4
            And some companies use many slightly different versions of some Chinese internals I've ran into. Check back daily. Some may have seen it before.
              Try this place. I buy parts for obsolete Streamway faucets here.
              http://www.plumbmaster.com/
              James
                Just from the loop style handle maybe a Grohe knockoff
                BigJim will know
                  Normally I do fairly well at playing "Stump the Chump."
                  But, this time you got me. Bill, you jinxed me!
                  I have no idea what this is. Perhaps a "hardware" brand.
                  Some after market companies like Sexauer and Plumbmaster made their
                  own stuff. But I don't think it's one of those two. I spent some time
                  going through some old catalogs with no joy. Sorry.
                    take the cartdridge into the couple local stores/ h.d. and lowes. it's probably a house brand and there are many knockoffs based off of the real brands.
                    the valve is mosrt likely a knock off of one.
                      My first guess was Nibco, but it just doesn't look right.
                      BTW, straighten that tub spout...it's driving me nuts.
