air bleeder valve is necessary?
  • air bleeder valve is necessary?
    is air bleeder valve is necessary for hot water tank? if yes, where is the best place to put it in? I guess the hot water line will be a better place than the cold water supply line because of the diptube in the cold line. installed on the horizontal line is recommended or it can be installed on any line?
    thanks,
    Re: air bleeder valve is necessary?
    No bleeder valve is needed for a water heater
    ________
    Toyota in motorsports specifications
    Mike
