Tekmar 256
  • Tekmar 256
    Hi everyone, I am new to this forum.
    I have a Weil Mclain CGA boiler. Last year I installed two Taco electronic ball valves controlled by a Taco zone valve control.
    I purchased a Tekmar 256 odr control.
    I was reading the schematic and my question is
    Can i just wire the 256 in series with all the safety wiring, basically taking the lead off of the aquastat to terminal 5 and then from 6 back to the aquastat then power the 256 with a 24v power source at 8 and 9.
    I was under the impression that the 256 will do the aqua stats job for controlling the water temp. I still want to keep the aqua stat in series.
    Currently the t stat calls for heat and the zone valve opens which turns on the pump and fires the boiler.
    I just want the 256 to control the water temp.
    Any help will be greatly appreciated.
