300 machine high pitch whine?
  • 300 machine high pitch whine?
    My 300 machine has developed a high pitch whine when machine is threading pipe. Any idea on what is causing this sound and what parts I need to fix it?
    Thanks
    Re: 300 machine high pitch whine?
    My experience with the 300 and 500 series machines is that they do have a high pitched whine while threading. But, If this were my machine, I would remove the top cover and inspect everything inside. It may be time to add grease to all the gearing, and inspect the motor mounts to assure the motor gear is lined up as it should be. Just my two cents worth, David
