Wanted Good not so expensive starter
  • Wanted Good not so expensive starter
    Just wanting some input on a good starter inspection camera system. I work at a small college but also do alot of other work. Can't put alot of money into one at first.
    Thanks
    Re: Wanted Good not so expensive starter
    There is no good one that is not expensive.
    What you need depends on what you want to do with it.
      You need a used one then.
        When It brakes He won't be able to afford to fix it anyways.
        Rod
        http://unclognh.com
          Thanks
          I am not sure if using "can't put a lot of money into" and "GOOD" can work in the same sentence here, at least for a piece of equipment like a sewer camera.
          This is what we call "Specialty Equipment" because when you can afford it, you are a SPECIALIST
          I personally would work on getting some money saved and then buying one, if you buy a cheap unit its only going to turn into a pile of crap, no pun intended.
          Just my opinion and 99.9% of the time I am wrong
            I'm thinking of 2500.00 or under 3000.00 Like I said a starter set up. Thanks for the smart *** remark.
              again, what do you want to do with it? size of lines? distances? need to locate? need to record?
              micro drain and explorer would come in in your price range. micro reel/explorer would be more versatile but don't know $ on micro reel.
              what's a compact going for?
                Whats your budget?
